Old 05-30-2017, 11:51 AM   #34 (permalink)
Merlyn2220
Deep Lurker
Creepy Van - '95 Ford E150 Cargo
90 day: 14.45 mpg (US)
I'm having tint installed on Thursday, which should increase it's creepy-factor substantially! It should also help decrease the blazing sun factor in the lunch and evening drives, so hopefully I can use a lot less A/C. The two tanks when using A/C were at 13.79 and 13.92mpg, so I'm pretty confident it's around 13.85 with A/C. My last fillup was 14.36 without A/C, which is basically the same as what I saw before I fixed the A/C. I'm running through this tank to confirm, since in the last tank I did about 50 miles @ 80mph with no drafting while rushing to get to the airport. I'm sure that hurt MPG by a little bit, but I'm not sure how much.
