Energy with out carbon?
HA!
They show solar panels.
Mono solar panels need liquid helium during production, I think they all need silicon doped with some funky rare earth metals, the mining of which requires a lot of waste radioactive elements to be brought up to the surface. Also very chemical and energy intensive.
The silicon based solar panel epoxy comes from the perto chemical industry.
Tempered glass, requires all the stuff glass needs, so natural gas to melt it and heat treat it.
Aluminum for the frames and everything that goes along with aluminum mining and recycling.
Wind turbines.
Require a base made with a few tons of rebar, 20 to 30 tons of concrete.
The monopole is 20 to 30 tons of steel, or maybe that was for each section of the monopole.
The nacelle is usually around 30 tons of mostly steel, that includes the gear box generator and swivel.
The hub is usually up to 10 tons of steel. Just the steel plate the blades bolts to is 3 inches thick and weighs more 2 or 3 cars.
Each blade can be up to up to 15 tons of mostly fiber glass.
Each wind turbine needs a transformer that weighs a few tons.
Each wind turbine has 50 to 150 gallons of oils, more if they are hydraulic actuated. Less if they are mostly electric.
Unlike solar panels at least almost all of the wind turbines parts can be recycled. With solar panels, you can recycle the aluminum frame and wires, that's about it.
If you love solar panels and wind turbines you also have to love the coal, oil, mining and petro chemical industry.
