Old 06-05-2017, 02:56 AM   #12 (permalink)
GKRenegade
Seems the renegade has recessed headlights and grill. If I put thin clear plastic to smooth it all out, that should help quite a bit with drag yes? If I did that with each recessed item and light on the front, it would have next to no drag especially if I were to silicone all edges. Any thoughts? And I did look under the jeep. No belly pan of any kind. But looks like I can find mounting points. Any reason I shouldn't just wall up the entire underside? Do I need to leave any gaps?
The Following User Says Thank You to GKRenegade For This Useful Post:
aerohead (06-10-2017)
