Old 06-05-2017, 12:05 PM   #21 (permalink)
Grant-53
This is a well designed tail and should be stable. It is rounded at the top and the Kamm end plate helps as well. The only problem might occur if there is too much weight in the back. An aspect ratio of between 3:1 and 5:1 with a 75% Kamm length is optimum.
