Originally Posted by PaleMelanesian
Just last month, I informally tested 55 vs 60 psi. There's a certain long but gentle downhill on my commute, about 1/2 mile long. 55 psi would just maintain speed at 40mph, while 60 psi would gain about 5, to 45mph at the bottom.
Originally Posted by whitevette
Excellent road test! As long as one pays attention to head/tailwinds and conducts these tests in the dry ( no wet, no damp!) the results should impress any disbeliever. Wait! Is gravity constant in your test area? LOL!
LOL! Dry both times, wooded back roads so wind is not a factor. Temperatures were about the same both times, mid-70's. They were two different days, but on my same commute, both with a cold start 2 miles earlier. Very much apples-to-apples, but not scientifically controlled.
I noticed the bit about only maintaining 40mph, so I checked my tires and found they were down to 55. I inflated to 60 and recorded the 45mph terminal speed the next morning.
