Thread: My ML350 2003
Old 06-05-2017, 08:29 PM   #21 (permalink)
teoman
At some point i will try externally charging the battery all the time to see if i can get the alternator to cut off.
Can you recommend any oils? The spec only lists a single weight. What I have in there is pretty old and I should change it soon.
I have to use the AC. But i try to switch it on only while engine braking. Damn i wish the ecu's for these were open source.
Is there such a circuit to put the brake light in series with the ac clutch?
