Old 06-06-2017, 08:09 AM   #1 (permalink)
pugmanic
EcoModding Wannabe
Hype-brid - '10 Toyota Auris HSD T-Spirit
Question The Dreaded VG's again...
I have a question over vortex generators. I understand that they have very specific uses, and come with their own drag penalties, but I was wondering if they can be used to reduce certain problem areas of auto aerodynamics.
Looking at their use in Aircraft, they are predominantly used to keep flow attached to a wing with a high angle of attack, to lower stall speed of the wing.
Would it not make sense to install them in front of the front wheel arch/well? By installing one or more VG on the front bumper/wing, would this smooth airflow around the front wheels?
I have no means of testing or simulating this.
The Following User Says Thank You to pugmanic For This Useful Post:
aerohead (06-10-2017)
