cooling?
I can't imagine either of the condenser fans coming on at 55-mph.The ram air should take care of that even with the grille block.The compressor load might move the engine closer to the BSFC peak,and engine run cooler,however it seems like the T-stat should maintain design coolant temp regardless.I suspect paranormal activity!
