Old 06-16-2017, 06:24 PM   #4 (permalink)
oil pan 4
I wouldn't try to put a coolant jacket around the transmission at all. Transmission cases are die castaluminum. Die cast aluminum is nearly impossible to weld with out cracking it.
If I were going to do it I would replace the fill and drain plugs with 90° barb nipples and pump the oil to a heat exchanger and through a filter too then back to the transmission with a marine oil pump.
I will likely be doing this on my firebird six-speed transmission at some point.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
Daox (06-18-2017), Fingie (06-19-2017)
