Old 06-17-2017, 06:12 AM   #8 (permalink)
cRiPpLe_rOoStEr
Just to remind that a leaner AFR usually leads to a higher EGT. BTW can you eventually mess with the VVT to make it go "Atkinson-capable" like that Toyota 8AR-FTS engine currently fitted to some Lexus models?
Originally Posted by Baltothewolf View Post
Or, just fabricate a pipe to swap out for the cat so you don't have to worry about it, and when you gotta smog swap it back.
Probably would need to revert to stock tune in order to get approved on the smog test anyways.
