Old 06-20-2017, 08:03 AM   #72 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
So I attached some pictures of my prior work on the radiator, hoses, and coolers mentioned previously.
Last night I started tackling the fuel filtration system while waiting for my oil cooler lines. The basic setup will be a pre-filter, electric fuel pump, and post-filter. This will all fit on the drivers side frame rail, back behind the torsion bar cross-member. (Where the GMT-400 pickup trucks have their fuel tank.) I would have put it all roughly where the stock electric fuel pump was, but the torsion bars were in the way with the filters I am using. I had to fab some brackets which will bolt onto the top of the frame and come out and down to allow the filter housings to bolt on the inside.
ID:	22022   Click image for larger version
ID:	22023   Click image for larger version
ID:	22024   Click image for larger version
ID:	22025   Click image for larger version
ID:	22027   Click image for larger version
ID:	22028   Click image for larger version
ID:	22029   Click image for larger version
