Old 06-20-2017, 11:41 PM   #8 (permalink)
cliffordlj
Ecomodding Crazy
zach mobile - '96 Chevrolet s10 ls
90 day: 26.95 mpg (US)
Walter Smurf - '05 honda civic lx
90 day: 41.03 mpg (US)
Dota - '04 Honda Insight
Gen-1 Insights
90 day: 58.65 mpg (US)
pixe - '18 honda civic SI
90 day: 42.82 mpg (US)
As far as what daox said, 1 mph at 5 is not the same as 1 at 40 mph. The kenetic energy scales with the square of the speed. You can illustrate this by coasting up a hill and observing the vertical displacement will be significantly more as you slow from 40 to 20 as it will be from 20 to 0. However if driving a manual anyways keeping the speed above your first gear idle rpm will reduce clutch wear which is good
The Following User Says Thank You to cliffordlj For This Useful Post:
freebeard (07-13-2017)
