Old 06-22-2017, 01:24 PM   #7 (permalink)
oil pan 4
Those cells are about double the efficiency of normal cells.
Still laying almost flat they will make about half of name plate, even in summer.
Those panels must not be getting very hot or something where they are because 6kwh from that much panel sounds a little hard to believe.
If it can be done then great.
I'm going to assume these double normal efficiency cells cost more than double normal cells right?
When will these 40% cells be made into panels that people with marginally above average disposable income can afford?
