Thread: Speed bumps.
Old 06-27-2017, 01:59 PM   #20 (permalink)
ChopStix
Primer is still paint!
ChopStix's Avatar
Originally Posted by JockoT View Post
Take it the kill switch just temporarily switches off the ignition. When you release it do you just lift the clutch to restart? Or does the kill switch just shut off the injectors, meaning the engine continues to pump with no need to bump start?
Yes, it kills the ignition. (switch pressed the engine is off, released the engine can run) While the engine is off you are just coasting with the clutch depressed. Here's a topic explaining pulse and glide better. Also others have done other variations of it on newer cars, also linked on this forum.
http://ecomodder.com/forum/showthrea...lide-3080.html
