Old 06-30-2017, 01:15 PM   #4 (permalink)
aerohead
curve
If you're up to it,consider building out the rocker panel portion of the entire body,allowing some clearance off the outer face of the tires,extending down,even with the belly of the van.
From there,it would be very straight forward to do full skirts,even on the front if you wanted.
