Thread: Electric Fan
Old 08-19-2008, 09:22 AM   #9 (permalink)
mavinwy
Neon1 - '97 Neon highline
90 day: 27.26 mpg (US)
It is not a hard modification so long as you take your time and do it right. The flex-a-lit fans work well and the instuctions that come with them are decent.
I'll also add to remember to check the thickness of the fan(s) you are looking at installing. Too thick and you might have it running into engine components. (they make thin style fans for tight applications)
Also having a shroud that covers the non fan parts of the radiator makes the fan more efficient when it does need to run.
Jim
