Old 07-05-2017, 08:20 PM   #2 (permalink)
jray3
Karmann Eclectric
jray3's Avatar
Odysseus - '00 Honda Odyssey
MR BEAN - '12 Mitsubishi i-MiEV SE
Karmann Eclectric - '71 VW Karmann Ghia Electric Conversion
BOB - '87 Ford 250 Lariat ext cab
apples and oranges?
A teardrop and a high-rise are not very comparable on fire risk, especially given that polymetal is approved under US fire regs for buildings under 40 feet tall. (according to the Wikipedia article you referenced). Yes, if you apply two crossed torches to the teardrop skin for 30 minutes (or tip over a combustion heater), your trailer may burn. Just like all the other trailers made of plywood and filled with wood cabinetry and combustible fabrics.
The basalt fiber doesn't seem comparable because it is a fabric and not a rigid panel. I'd love to build a trailer out of fabric and resin, but it requires a lot more skill and time to make it look good and perform well than fitting together some rigid panels.
I found references to some prototype basalt wall panels, but other than simulated stone cladding, no commercial products. Is a basalt alternative panel to polymetal out there?
2012 Mitsubishi i-MiEV, 112 MPGe
2000 Honda Odyssey
1987 F250 Diesel, 6.9L IDI, goes on anything greasy
1983 Grumman Kurbwatt, 170 kW "Gone Postal" twin
1983 Mazda RX-7 electric, 48 kW car show cruiser
1971 VW Karmann Ghia electric, 300 kW tire-smoker
1965 VW Karmann Ghia cabriolet, 1600cc
Have driven over 100,000 all-electric miles!
The Following User Says Thank You to jray3 For This Useful Post:
Xist (07-22-2020)
