07-10-2017, 11:33 AM
Welcome, stefanv!
The SL1 is a great platform for modifications. There are lots of threads here about them.
Consider also a 5th gear swap, depending on which ratios you have. It's not a difficult job, from what I recall. (Doesn't even require removing the transaxle - the gear set is under the stamped steel cover on the end.)
