Old 07-10-2017, 03:53 PM   #12 (permalink)
redpoint5
Originally Posted by cliffordlj View Post
As far as what daox said, 1 mph at 5 is not the same as 1 at 40 mph. The kenetic energy scales with the square of the speed. You can illustrate this by coasting up a hill and observing the vertical displacement will be significantly more as you slow from 40 to 20 as it will be from 20 to 0.
If it takes an increasing amount of energy to gain each increment of speed, then why does gravity have a constant acceleration rate (9.8m/s/s) despite the increasing speed and constant force?
