Old 07-13-2017, 12:23 PM   #2 (permalink)
Fat Charlie
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
It's accurate once it's calibrated, but it's relatively accurate even before that- higher numbers, whether or not they're "real" are higher than lower numbers.
Gearing can leave the engine at its most efficient spot, and steady cruising doesn't put too much load on an engine, especially on something aerodynamic. My Fit does best between 40 an 50 mph because it's a brick.
Calibrate it at every fill up for a while, and the numbers will get more accurate and you'll be able to believe the screen a lot more.
Transmission type Efficiency
The Following User Says Thank You to Fat Charlie For This Useful Post:
EcoCivic (07-13-2017)
