Old 07-16-2017, 07:34 PM   #21 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
OP said that the engine was declared dead. There should be an oil pressure warning and a flashing CEL if pressure drops below some threshold. I'm not familiar with the Volt though, so I don't know if it has those indicator lamps. I know my Prius has no engine coolant temperature gauge.
In Chrome, if you right click on the image and select "Inspect", it will show you the URL where the image is listed. If you look at my linked image, you will see that Craigslist is hosting the image. The link will break a few days/weeks after the ad expires and they clear the image from their server.
He was mistaken, the Volt tells you when oil pressure is low, he assumed it was dead because the dealer said it was and because the pump was noisy.
The guy who bought it just flushed and installed an oil pump rebuild kit.
The Following 2 Users Say Thank You to rmay635703 For This Useful Post:
redpoint5 (07-17-2017), roflwaffle (07-16-2017)
