Old 07-20-2017, 01:19 AM   #666 (permalink)
Michael Moore
Bob, I tried that with points I extracted from the template but once I turned on the curve analysis tools they proved to not be very smooth. I think the points have to be located properly to help the smoothness. Running the "fair curve" command several times helped, but the curve moved away from the template. The curves generated by the arc or ellipse commands are pretty much dead smooth, as I'd expect since they are mathematical constructs and not "let me guess that the point should go about here on this not very clear bitmap in the background."
http://www.eurospares.com
