Old 07-22-2017, 01:26 PM   #12 (permalink)
Daox
PART 3
How do I put this jumble of TEGs together to make some powah?
Yay, we're getting 36 TEGs to generate around 210W and significantly reduce the load on the alternator. But, how do we slap the TEGs on the car and make it work? Lets get to that now.
Note, this is just a quick way I came up with to slap the TEGs on the exhaust. There are many other ways you could possibly do it.
You'll notice I've kept the number of TEGS divisible by four. This is intentional as the mounting of them will be on a square tube. Four sides to the tube, four TEGs keeps things all neat and tidy. This is also why I chose 40mm TEGs as they fit the square tube that kind of matches the pipe size the tube will be replacing. The square tube will replace a section of the exhaust. It would look something like this:
Then, you would need to add heat sinks to the cold side of all the TEGs to help cool them off and maintain the highest temperature differential possible. It would look something like this:
And beyond that, you have to find a way to bolt those heat sinks down to the tubing. The TEG modules are supposed to be under a fairly specific amount of pressure to ensure long life and good performance. Here is some of the guide from TecTegs.
ID:	22224   Click image for larger version
ID:	22225   Click image for larger version
The Following 2 Users Say Thank You to Daox For This Useful Post:
California98Civic (07-22-2017), oldtamiyaphile (07-22-2017)
