Old 07-22-2017, 04:23 PM   #15 (permalink)
RedDevil
90 day: 49.01 mpg (US)
Originally Posted by teoman View Post
How about the inner part as you describe, but instead of the heatsinkds it is encased in another square peofile tube which is a thermal syphon filled with water under a vacuum or lpg.
Or alternatively, what about a flat aluminum plate like part of a belly pan?
Or two L-shaped plates with TEGS to the sides, or for that matter, a plate with a square channel folded in to bond with TEGS on 3 sides, so the exhaust runs under it (I'm not fond of enclosing any part of the exhaust system between a belly pan and the rest of the car)?
About clamping force - no chance to use heat paste? That would provide full thermal conductivity even if the clamping force is low?
And last but not least - any estimates on how much weight it all will add?
This seems fairly lightweight so far - but it needs to be light to be worthwhile.
(subscribed!)
Daox (07-23-2017)
