Old 08-19-2008, 10:29 PM   #428 (permalink)
bennelson
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
Big-@ss charger revisited
Been thinking about chargers some more.
Made me remember that I already have a charger. A HUGE one that came with the forklift.
According to the specs on the charger's ID plate, it is:
Hobart model 1R18-450
AC input: 208/240/480 single phase, 60 hz.
Max amps 29/26/13
DC output
Volts: 36 Cont Amps:65 Max Amps 95
It looks like I only need to change some jumpers inside to convert it to 240 volts.
Another set of jumpers controls output amperage, but it only has a scale saying higher and lower, not a listing of what the actual amperage would be.
Looks like I need to talk to an electrician.
This thing sure has a big transformer inside it. There is also a weird looking part towards the back, which I think is a very large resistor. This thing must get hot when it's running.
Even if I can't use this charger, it would still be a great source for a 200 amp ammeter, some cabling, and fuses.
Here are a few photos of it.
Is the above a giant resistor?
Plugs. 30 amp twist lock and large Anderson.
See all the forklift charger photos, including spec plate, etc. at:
Charger Images
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
