Old 08-07-2017, 12:52 PM   #28 (permalink)
Panther140
Panther140
Originally Posted by jamesqf View Post
Buying a well-used small Honda, Toyota, or similar is going to cost you a heck of a lot less than trying to develop this sort of hybrid system. (As has been noted, you can't put that much power through a standard V-belt, for one.) If you really want ROI, drive the car all the time, except when you actually need to haul or tow something.
Wouldn't necessarily be limited to a V belt. Cogged pulleys work well.
I'm also finding some rather inexpensive 10-15kw brushless motors from china that would be capable of sufficient duty cycle for what I'm intending to do with this.
A commuter car would have to bring a sunken cost of no more than $1000 and also get 40+mpg in order for me to break even on it before I am done commuting (I'm only commuting to this job location for 1 year). After that, the car would serve almost none of my purposes.
2007 Silverado 1500 2wd flex fuel with active fuel management. 33" Nitto Terra Grappler tires. 2.5" motofab front end leveling kit.
