Old 08-08-2017, 04:47 PM   #39 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by 93tracerwagon View Post
I'd like to upgrade our 2007 Dodge/Jeep 3.7 v-6 I believe the original are 2 hole. 4 hole are pretty easy to find but cannot find 12 hole.
You should be able to use the 0280156161 injectors, just fine. You will have to consider, though, that you cannot use the injector clips. That's fine, because the fuel rails are bolted down and the injectors won't be going anywhere.
Originally Posted by ksa8907 View Post
how do you find this information? I have searched high and low and i cant find anything about the flow rate of the stock injectors.
What injectors are you looking for? From RockAuto.com, the 2008 Cadillac CTS with the 3.6L engine uses Bosch 0280156300 injectors rated at 246 mL/min, and the 2012 Chevrolet Traverse uses a direct fuel injector. You might see some gains by swapping your CTS's injectors with the 12-hole ones.
The Following User Says Thank You to t vago For This Useful Post:
ECONORAM (08-08-2017)
