Old 08-08-2017, 05:58 PM   #13 (permalink)
redpoint5
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
Originally Posted by JohnAh View Post
I've been thinking about adding a super capacitor buffer that could hold the charge for at least a few minutes and allow one start, but their voltage drop and raise so I guess some charging circuit is needed...
A supercap might be able to start the vehicle, but if your battery is too weak to do so by itself, then it is already discharged to the point that damage has occurred. Supercaps don't solve the problem of battery drain during EOC.
A better solution is to buy a deep-cycle battery, or to install more battery capacity.
If you buy a big enough battery, you can even disable the alternator and charge from home.
