Old 08-20-2008, 04:49 AM   #50 (permalink)
Hacksaw
Hacksaw's Avatar
GOT MPG? - '95 Metro Hatchback 3cyl/5-speed Base Model
90 day: 44.74 mpg (US)
1337MPG - '97 Metro Lsi
90 day: 36.51 mpg (US)
55HORSE - '95 Metro Hatchback
90 day: 37.79 mpg (US)
DOOPULR - '99 K1500 Suburban SLT
90 day: 9.79 mpg (US)
Scar's Tracker - '96 Tracker Base
90 day: 23.46 mpg (US)
Originally Posted by vtec-e View Post
Well, i installed the vacuum gauge and here it is, in its "temporary" home.... showing idling pressure of
in inches of mercury. Does this indicate anything alarming to anybody here? I'm a bit of a novice when it comes to in depth engine theory! The install was easy enough, finding a t-piece in work was the hard bit. It's connected to the brake vacuum hose at the manifold and the line going to the gauge is a length of 3mm pneumatic hose. I had to change the response time of the gauge to the slowest setting as it was jumping like a mad thing. Not by huge amounts now, just by a few inches but it was flashing too much so i slowed it down and now it's okay. It holds its memory when powered down so that's nice!
ollie
Your idle is great. It's on the high side of were it should be. Did you get that one off the machine you were telling us about? It looks good, I hope you save many gallons with it!
Hacksaw
