Old 08-13-2017, 09:58 PM   #207 (permalink)
M_a_t_t
Ecomodding amateur
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl
Team Chevy
90 day: 16.04 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 58.45 mpg (US)
The best handling conditions are when all 4 wheels have the same weight on them. I couldn't find the article I was reading on doing it diy, but its called corner balancing. I would imagine with motor, transmission, and (half?) the batteries in front it would be pretty front biased.
I would go for one of two things probably:
1. remove gas tank and put the batteries in its place, chargers in spare area
2. CUt a whole in the floor and put a box similar to this to gain access to them from inside, then put it all in there. If the gas tank and spare area are next to/ above and below each other.
However, I don't know exactly what the layout of your car is, but that is what I would go for.
Good luck
At 55 mph, a 10% drag reduction translates to a 5% increase in fuel economy. At 70mph,a 10% drag reduction translates into a 4% increase -Phil Knox (Aerohead)
