Old 08-20-2008, 10:17 AM   #38 (permalink)
PaleMelanesian
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
I like to accelerate at about 50% throttle at lower speeds, working up to about 80% at higher speeds and gears. Something like this:
1st gear: just to get moving. Shift before 5mph.
2nd gear: 50% throttle
3rd: 60% throttle
4th: 70% throttle
5th: 80% throttle pulse, then glide, then pulse again
Watching the scangauge, these throttle points roughly correlate to 70-80% load in each gear. At low speed and rpm, there's less power available, so it takes less throttle to reach the same load %.
80% load is about 12 on the MAP gauge, so near WOT but not quite there. I find that my Honda will go to Open Loop at about 90% load.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
