Old 08-21-2017, 04:26 AM   #31 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Originally Posted by The Toecutter View Post
I have sort of figured this project wouldn't be completed until at least the 3rd body.
I would change that to "3rd body and chassis." In automobiles, just doubling the power usually is as much as one chassis can be modified to take gracefully. The electrics have the best chance of staying suitable, but they are evolving quickly and that could also change your mind, as might the performance numbers on #2. With my body weight added, I'd have about 40 lbs/hp, so I wouldn't out-accelerate many cars, unless your motor is just rated at constant duty and the controller can heat it up.
Have you compared estimates between fairing the wheels separately vs installing a 40" door? Some houses are much improved by double doors, too.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
The Toecutter (08-21-2017)
