Old 08-24-2017, 09:33 PM   #18 (permalink)
ar5boosted
ar5boosted's Avatar
Originally Posted by teoman View Post
Sounds good in theory.
First will the holes provide enough flow?
Not sure yet. But air compresses easily and I'm thinking how pin-hole size (0.5 - 2mm ?) pressure relief valves could relieve pressure.
I know my cylinders get to 160psi with a compression tester.
If I concentrated I could probably calculate [ie find on google] how much air can flow through 3x 2mm diameter holes at say 1200 rpm.
Second, would fuel and air not enter with the compression stroke and potentially burn up your solenoid?
I was only thinking of using this as part of cylinder deactivation when no fuel was being combusted. So when fuel was applied to the cylinders, the valves would close.
2003 Renault Scenic - 30% more power with no loss in fuel economy.
1991 Toyota GT4 - more economical before ST215W engine-swap.
previous: Water-Injected Mitsubishi ~33% improved.
future - probably a Prius
