Old 08-26-2017, 11:04 PM   #16 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Air dam time
I cut my brackets from Alu paver edging. It's light and sturdy, rust free, easy to work, is already broken up into segments and half the brackets are even pre-drilled.
I cut it with a regular wood working blade. I've used fancy TCT blades in the past but don't think they're worth the expense and hassle of swapping blades.
I used bolts, washers and lock nuts to secure these to factory holes in the bottom of my bumper cover (the holes are there for a factory option body kit).
The air dam itself is 75mm (?) plastic lawn edging that I recycled off my old previous Renault. Attached to the brackets with galvanized, self drilling 'stitching' screws.
This car is essentially a sedan with a 1" suspension lift, so there's plenty of air getting under the car. The airdam has had a noticeable effect on coast distances and noise. Really makes you wonder why the OEM's didn't do something so simple in those days.
ID:	22520   Click image for larger version
Name:	IMG_20170823_154446 - Copy_cr.jpg
ID:	22521   Click image for larger version
Name:	IMG_20170823_144045 - Copy.jpg
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
aerohead (09-25-2023)
