Old 09-06-2017, 10:18 PM   #20 (permalink)
roosterk0031
The last few I've tossed I had to really rip the cord to start, the few I pulled the heads off because I thought it was leaky valve seats had very little valve lift. Others couldn't start them at all, but a fast enough pull they would start but low power output and if bogged down would die. I had a Ninja 250 act similar when the valves where too tight (the day I bought it).
Had a snapper rider I couldn't keep the head bolts tight and would start leaking. Mice packed the housing with fiberglass insulation. Once cleaned and bolt tightened it was fine.
