Old 09-06-2017, 11:37 PM   #214 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I'm almost ready to start shaping the foam blocks into a nice, streamlined shape with the surform and sanding block. To make it more durable and easier to install, I glued 1/4" plywood board with carriage bolts sunk in to the bottom board:
Now I can install or remove it with access to only one side.
I've been building up the shape with more foam board:
I've glued a little more on the sides tonight, and hopefully this weekend I'll get the top board on. Fiberglass arrives tomorrow; once I get it shaped, I'll glass the whole outside, then cut the hatch lid, then do the inside.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 4 Users Say Thank You to Vman455 For This Useful Post:
aerohead (09-09-2017), BamZipPow (01-31-2018), Daox (09-07-2017), Xist (09-07-2017)
