Old 09-09-2017, 12:57 PM   #18 (permalink)
aerohead
holes
I've used existing frame holes.
Fender washers which just fit within the frame hole,are captured by larger fender washers outside the hole right against the frame rail,and drilled angle metal is bolted through the holes in the fender washers,extending down,providing a new place to drill and bolt belly cross-members.
