Old 09-11-2017, 03:55 AM   #8 (permalink)
ar5boosted
ar5boosted's Avatar
Originally Posted by Stubby79 View Post
"Mechanical" voltage regulator? I never paid any attention to old cars...that just sounds nutty to me!
My grandfather mentioned that they had these on trains. So to control the Speed the driver would move a control-rod to the appropriate resistor needed to go at a particular speed.
If you have an alternator that spins, it's voltage will increase as rpm increases and if you went too fast obviously you would blow your globes.
I've never seen one but I'd be guessing some type of centrifugal switch to push to a higher resistor to limit current and voltage.
Yes, it's all solid state vregs now.
2003 Renault Scenic - 30% more power with no loss in fuel economy.
1991 Toyota GT4 - more economical before ST215W engine-swap.
previous: Water-Injected Mitsubishi ~33% improved.
future - probably a Prius
