Old 09-11-2017, 07:39 PM   #18 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by Stubby79 View Post
The larger reason I have my lights on is so that others - those without night vision goggles - can see ME. I live in a city, so I can see fine without...but not a chance I'd go out there without them working.
If you want to save power/alternator drag, switch everything over to LEDs. I'm quite pleased with my ~$20 ebay LED headlights; they're about the same brightness as the power-hungry halogens but only use 1/4 the power. All bulbs converted over only pulls about 5 amps. You can go alternatorless if it's important enough.
YOu know it's ILLEGAL to alter headlamps?
the issue has nothing to do with 'brightness'.
tak a picture of the light from the correct bulb shining on a wall, the replace 1 of the bulbs and take a camparision pic.
It wont be the same.... it cant be. physics says so.
THe hot spot on the old bulb and the led are different.
THe headlamp assembly was DESIGNED to use the original bulb. period.
the are numerous post on this that used to have pictures...... (oh well)
put the article should be clear.
FACT: the led DOES NOT have the same hot spot, nor is it in the same place.
Your 'new' brightness is increased glare being incorrectly bounced off the reflective surface.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
