Old 01-15-2008, 03:53 PM   #2 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
If you can get airflow (mass) from the OBD2 port, you should be able to do a simple instant fuel economy calculation based the stoichiometric air fuel ratio of 14.7 to 1. Factor in your speed, and you're good to go.
The SuperMID works by using a (user-programmed) volume for the fuel injector. It counts fuel injector pulses per distance traveled and bases the calculations on that.
