Old 09-12-2017, 10:25 PM   #24 (permalink)
S Keith
I don't see where you posted miles on the clock.
Concerning A/C use - even in mild climates, the Prius battery will get very hot - 120°F+
Sparing the A/C is usually a false economy in that the improved mileage you're getting means you'll replace your battery sooner. If it's under 80-85°F, it probably doesn't matter.
In case you weren't aware, the Prius compressor is all electric, and it varies its speed based on demand, so rather than cycling on and off like a traditional system, it dials back power usage to what it needs. Treat it like the house - Auto mode, recirc always on and control driver comfort with the temperature setting.
A good rule of thumb is - if a hot-flash prone lady isn't comfortable, the battery is too hot.
