Old 09-15-2017, 02:08 AM   #7 (permalink)
oil pan 4
My small generator has a 7 gallon tank then I added another 4 gallon tank on top of it, the the big generator has a 16 gallon tank.
The big one uses 1.6 gallons per hour at half load.
The 3x gasoline prices is if you use swapped out 20lb tanks. Bulk propane would be cheaper.
