Old 09-15-2017, 03:19 AM   #8 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
My small generator has a 7 gallon tank then I added another 4 gallon tank on top of it, the the big generator has a 16 gallon tank.
The big one uses 1.6 gallons per hour at half load.
The 3x gasoline prices is if you use swapped out 20lb tanks. Bulk propane would be cheaper.
You're absolutely right about swap-tanks costing too much. And having to get my tank refilled means going out of the way; I probably wouldn't want to keep messing around if I had to do it very often.
On the other hand, since I don't use my power equipment much, it's nice not having to put up with gas going off and/or it wrecking the carb when I forget/can't be bothered to drain it every time between uses. I'm stoked with the idea of not having to mess around for an hour to get my power equipment started each time I go to use it.
