Old 09-16-2017, 11:46 PM   #23 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Aero modding continues. From the Wiki we know that a tonneau and cab deflector is 80% as good as a full aero shell. I already have a van so I want to retain the open load bay.
I have factory inserts under the roof, which would be either for the factory full shell or sports bar:
I found some ally strip in my recycle bin. It had previously been bent for a solar panel install so they are a bit wavy, but they were free:
Tip: if you want square bends using a vice, use a set square to make sure you've clamped your stock perfectly vertical I also used pipe bending pliers to help with the curves.
I don't know why people are so stuck on coroplast, when the other aeromodding staple, lawn edging can be use to make long lasting and good looking deflectors, spats etc etc.
I used electrical tape to help hide the supports:
Road Test.
While I have no ABA test, high speed shows that the soft tonneau doesn't balloon any thing like it did before.
It also helps shade the interior and add a little privacy, which are both side benefits.
This was a quicky install using what I had at hand. I now have some shiney new alloy strips and I bought some 6" edging to replace the 3" that I have at the moment.
The 6" edging will also make great tyre spats.
Name:	inserts - Copy.jpg
ID:	22691   Click image for larger version
Name:	brakets - Copy.jpg
ID:	22692   Click image for larger version
Name:	IMG_20170903_125642 - Copy.jpg
ID:	22693   Click image for larger version
The Following 2 Users Say Thank You to oldtamiyaphile For This Useful Post:
freebeard (09-17-2017), puddleglum (09-17-2017)
