Old 09-17-2017, 09:10 AM   #19 (permalink)
Shepherd777
Grand Imperial Poobah
Shepherd777's Avatar
Wood rots, coroplast sags.
Polymetal is polypropylene plastic skinned in aluminum. Typically 3mm thick with .007" skins, but it's available one-sided and Grimco MaxMetal is avaiable with .014" skins. It comes in 5x10ft and 4x12 sheets. Stiff as 5/8" plywood at 1/10th the weight.
Yes it is expensive; but it's fit for purpose.
We use very similar stuff on my big truck. I think I may have the only Class 8 truck on the planet with a bellypan.
Strong and lightweight, Alumalite is the same weight as .040 aluminum sheet metal, yet 50 times stronger. The stuff we use is close to 1/4" thick, so it's slightly thicker than the Grimco MaxMetal. And the 1/4" thickness allows us to utilize standard 1/4" I.D. "H" channels to butt two sheets together, up to 102" wide.
Alumalite
I buy the black matte finish, product. It looks way sexy and one can actually see it when looking downward standing behind the cab, or when the hood is open.
Bob Sliwa
"Like a Midget at a Urinal, I knew I was gonna have to stay on my toes......."
http://www.airflowtruck.com
The Following 4 Users Say Thank You to Shepherd777 For This Useful Post:
BamZipPow (09-18-2017), elhigh (09-17-2017), freebeard (09-17-2017), Xist (09-17-2017)
