Old 09-21-2017, 11:05 AM   #11 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 53.2 mpg (US)
Originally Posted by JockoT View Post
I wouldn't imagine that would be an aid to fuel efficiency.
Exactly. Although a flat belly pan to an upslope of a 4 degree diffuser can reduce drag. I am getting better mpg with this setup on my Golf. On sports cars the diffuser is usually much steeper to create downforce at the expense of extra drag.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
