Old 08-21-2008, 10:39 AM   #1 (permalink)
bennelson
Beta-tested it to death!
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
Alternator Delete VS starter motor
Hey everyone.
My 1995 Chevy S10 2.2L (4 cylinder) 5-speed manual transmission is currently getting 31 mpg.
I only have a few basic mods on it. Swapped mechanical radiator fan for an electric (from the Metro!) put in synthetic oil, and have a partial tonneau cover.
I am very interested in the idea of disconnecting the alternator to improve fuel economy. I would then simply recharge the battery from the wall with charger I would leave built-in to the car.
Essentially, this sort of makes a hybrid, because some of the energy the vehicle uses comes from a source other than the gasoline.
Two things are stopping me from doing this. Daytime running lights, and using my starter after engine-off-coasting.
Daytime running lights would obviously wear down the battery much quicker than NOT having them on. Is anyone familiar with a simple way of disabling them? I have heard to put on the parking brake one click to turn DRLs off. I am a little afraid of clicking too far and adding drag. Maybe I could get in there and find the actual switch the is hooked up to, pull it out and modify it to some sort of manual override?
I do some engine-off-coasting, a lot of it coming up to traffic lights. If I coast to a light and am stopped there, then I have to use the starter to restart the engine to pull away once it's green.
I don't know how many times I could use the starter without the alternator. I think I might naturally want to turn the engine off LESS OFTEN if my alternator is disconnected.
If I disconnected the alternator, I would also replace the starting battery with another battery type, such as an Optima Yellow Top, or something similar. Starting batteries do NOT like to be deep cycled.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
