Old 08-21-2008, 12:21 PM   #8 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
I would generally agree with you. I can't say weather those are optimal, average, or worst case numbers.
However, I'd like to clarify that it doesn't require anywhere near 50hp to keep you going down the road even @ 65 mph. From my general calculations using a conservative drag coefficient of .5 and a frontal area of 1.995m^2 (also conservative), you only need 19.7hp to keep you going 65 mph down the highway. Your Cd and frontal area are likely a bit better than those mentioned, so I'd estimate between 15-19hp to keep you going on the highway. Knock that speed down to 40 mph and you only need 4.6hp!
