Old 09-26-2017, 02:25 PM   #170 (permalink)
teoman
teoman's Avatar
A3 - '12 Audi A3
Originally Posted by Jurgis View Post
Terve Latrom! Without any other mods 60MPG (3,9l/100km) is quite good. Which pressure do you use? I think 44PSI (3,0 bar) is the limit for the tyres used for small cars. Driving is not so comfortable but it saves a lot.
Did you ever try "pulse & glide"?
Try the 5th gear, speed up rather fast to 85km/h (53 MPH), release the clutch and let the car roll until the speed is 70km/h (43 MPH), then speed up again.
This style is not possible if you're not alone but on the next trip to Rovaniemi you will have chance to try.
Additionally I use EOC (engine off coasting), that means while rolling I switch off the engine but ignition must be on. That might be dangerous as driving curves and breaking is no longer supported. As long as there is no moose (hirvi) on the street ...
It is rated 5.6/4l or 4.4/3.2 depending on the year.
The Following User Says Thank You to teoman For This Useful Post:
TDFbound (11-25-2018)
