Old 08-21-2008, 03:38 PM   #53 (permalink)
vtec-e
vtec-e's Avatar
De Yaris - '04 yaris T2
90 day: 69.55 mpg (US)
Hi azlar. Under full throttle it goes to zero and under normal acceleration, it's around the 15 inch mark but varies quite a bit. I i looked at my options regarding where to connect to the manifold and i had a line going to the fuel recirculate valve back to the tank. I didn't want to connect to this as i might upset the vacumn response time to the fuel valve and maybe decrease mpg as a result. I may be wrong but that was my worry. Of course, meddling with the brakes has a potentially much worse end result. I'll get some fittings in work and see about tapping into the fuel recirculate valve. Gotta be safe eh?
ollie
